Marketing
Build a stronger campaign brief—starting with what you already have
Why start from scratch when your past work already holds the answers? Dash helps you create a high-impact brief by pulling from existing campaigns, messaging docs, research, and templates—so your team can align faster and launch smarter.
How Dash helps
- Use a campaign brief template in chat to kick off your draft
- Add past materials like content, performance data, or research to inform the brief
- Tailor the draft based on your goals, product, or audience
- Adjust tone to fit your brand or key stakeholders
- Export or save your brief to a Stack for easy access
Try prompts like
- Start a new brief for [product] using our last GTM launch as a starting point
- Scan these files and draft a campaign brief tailored to IT decision-makers
Already a Dropbox Dash customer?
Try these prompts
7 億人以上が信頼を寄せる Dropbox の独自開発ツール
.webp)
